Latest post 10-30-2010 11:39 AM by Ignace. 2 replies.
Page 1 of 1 (3 items)
  • 10-29-2010 7:14 PM
    • Maurice
    • Not Ranked
    • Joined on 11-26-2007
    • United Kingdom
    • Posts 56
    • Silver Member
    Beolink 5000 opperation
    Can anyone explain if its possible to opperate a beocenter 9000 with a beolink 5000 i have so far only managed to turn the beocenter OFF with it Laughingits just the two items no link or any thing! and can it get the CD to repeat play?
    sorry if this sounds a dumb blond type of question ...
    Maurice
    Filed under: , , ,
  • 10-30-2010 2:44 AM In reply to
    Re: Beolink 5000 opperation
    Hi!
    You have to make Bl 5000  One Way for Audio. Download user manual from www.bang-olufsen.com if you don´t know how to do it
  • 10-30-2010 11:39 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Hi, to set the Beolink 5000 to 1-way communication:
    * press and hold Stand-By untill the display shows: STD. BY SYSTEM
    * press SHIFT , MENU
    display shows: TRMINAL SETUP?
    * press PLAY
    display shows: VIDEO TWO WAY
    * press arrow up/down
    * PLAY
    * arrow up/down
    * PLAY
    display shows: TRMINAL ACCEPT
    Beolink 5000 will return to stand-by
    and is now set to 1-way
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
