wonderfulelectric:What I meant was it doesn't require as much regular cleaning as the others and doesn't malfunction as often as the besound 9000 because it is less complex. The Beosound 3200 doesn't have a good harddisk recording system. It records everything very compressed so the sound will not be as good as from direct from cd. Beosound 4 will be a better choice since you might probably be using more of its functions. However, it doesn't have a digital output which might be a problem should you decide to upgrade to DSP speakers in the future like the Beolab 5 in the future. I don't own the Beosound 4 exactly because of that although I admire the design. My Beosound 9000 broke down once and the older version broke down a couple of times, it was because of dust.
Then I suggest that you buy a better vacuum cleaner or use it more often!
I have known most of the B&O designs to malfuntion beacause of dust and I don't see the Beosound 4 being any different. Regular cleaning of the laser lens has been neccessary ever since the introduction of Beocenter 9000 and all semi-open designs will suffer the same.
The chances of most normal folk being able to afford or want to slpash £10K+ on a pair of speakers is very remote and certainly not very high up the list a criteria for buying a cd player.
The Beolab 5's maybe, just maybe able to allow you to distinguish between cd players but I have to be honest and say that for £10k I would want the band in the room with me!
