1st March February 2012
Latest post 06-29-2007 4:53 AM by BEOfreak. 6 replies.
06-29-2007 1:43 AM
BEOfreak
- Joined on 04-17-2007
- Odense, Denmark
- Posts 63
Is there a way to connect a Lintronic unit to the control signal in the scart socket so you can control your non B&O equipment from a linkroom? BEOfreak
Avant CTV 28", V6000, DVD1, BC9000, BS3000, BL4000, MX4200, CX50, BeoCom 2, Beocom 6000, LC1, LC2
Kevin
- Joined on 02-15-2007
- Moderator
- Posts 1,256
The best person to answer that is Michael at Lintronic who is very helpful. Check out his website. cheers, Kevin
BEOfreak
- Odense, Denmark
- Posts 63
As far as i understand, the Lintronic unit require a IR input signal (and then translate it to a non B&O IR signal). When I press DVD in a linkroom, the signal is transmittet via masterlink to my Avant (in the masteroom) and then to the Avants scart socket where it normaly will control a DVD (via the scart cable). I want to be able to control a non-B&O DVD/HDR from a linkroom. A solution could be a DVD-controller or One-remote, but the Lintronic unit is more flexible. Best regards BEOfreak
BEOfreak
- Odense, Denmark
- Posts 63
Hi Heinz, I have looked at the oneremote solution, but I want it to be more flexible (I want to define which botten does what) like Lintronic. Best regards BEOfreak
BEOfreak
- Odense, Denmark
- Posts 63
Thanks Kevin, I'll try Michael directly. Best regards BEOfreak
Page 1 of 1 (7 items)
