Latest post 06-29-2007 4:53 AM by BEOfreak. 6 replies.
Page 1 of 1 (7 items)
  • 06-29-2007 1:43 AM
    • BEOfreak
    • Not Ranked
    • Joined on 04-17-2007
    • Odense, Denmark
    • Posts 63
    Lintronic and scart
    Is there a way to connect a Lintronic unit to the control signal in the scart socket so you can control your non B&O equipment from a linkroom?
    BEOfreak
    Avant CTV 28", V6000, DVD1, BC9000, BS3000, BL4000, MX4200, CX50, BeoCom 2, Beocom 6000, LC1, LC2
  • 06-29-2007 1:58 AM In reply to
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Re: Lintronic and scart
    The best person to answer that is Michael at Lintronic who is very helpful. Check out his website.
    cheers,
    Kevin
  • 06-29-2007 2:06 AM In reply to
    Not sure about your question because it assumes that you want to run a long SCART cable from a link room which you should not do.
    Lintronic can control a link room because it has an RS232 interface cable which can link units together.
    Regards Keith....
  • 06-29-2007 3:36 AM In reply to
    • BEOfreak
    • Not Ranked
    • Odense, Denmark
    • Posts 63
    As far as i understand, the Lintronic unit require a IR input signal (and then translate it to a non B&O IR signal). When I press DVD in a linkroom, the signal is transmittet via masterlink to my Avant (in the masteroom) and then to the Avants scart socket where it normaly will control a DVD (via the scart cable). I want to be able to control a non-B&O DVD/HDR from a linkroom. A solution could be a DVD-controller or One-remote, but the Lintronic unit is more flexible.
    Best regards
    BEOfreak
  • 06-29-2007 4:28 AM In reply to
    • seheiste
    • Not Ranked
    • Joined on 04-21-2007
    • Stockholm
    • Posts 27
    this could be a solution.
    http://shop.oneremote.dk/catalog/
    /Heinz
  • 06-29-2007 4:50 AM In reply to
    • BEOfreak
    • Not Ranked
    • Odense, Denmark
    • Posts 63
    Hi Heinz,
    I have looked at the oneremote solution, but I want it to be more flexible (I want to define which botten does what) like Lintronic.
    Best regards
    BEOfreak
  • 06-29-2007 4:53 AM In reply to
    • BEOfreak
    • Not Ranked
    • Odense, Denmark
    • Posts 63
    Thanks Kevin, I'll try Michael directly.
    Best regards
    BEOfreak
