Bonjour Keith,
Merci pour le compliment...! Votre Français est parfait :-) et surtout merci pour la disponibilité et la rapidité pour la réponse de samedi...
I have took the XML file into the BeO5 and the Samsung is working with the test button (great!)
I'm very happy that the IR Remote Code Analyzer that I have buy is Working and can help to make some files.
What will be the next step to generate the XML file for using totally my Samsung with the BeO5.
After i can Upload the file for the other members of Beoworld.
Dans l'attente de vous lire,
cordialement, Daniel.
