Latest post 09-03-2010 3:59 PM by dan88270. 8 replies.
Page 1 of 1 (9 items)
  • 08-21-2010 5:45 AM
    XML file for Samsung SHD 85 Orange fench TV
    I'm searching XLM file for French TV on Orange (Samsung SHD 85). I will use my BeO5 for drive it. Has some one create the XLM file for it ?
    Thank a lot for all your help.
    Best regards and sorry for my poor English...
    Daniel
  • 08-21-2010 12:13 PM In reply to
    Re: XML file for Samsung SHD 85 Orange fench TV
    Daniel,
    Your English is very good..  J'ai besoin d'améliorer mon français si vous avez très bien fait
    I have responded to your e-mail you sent to me earlier..
    Regards Keith....
  • 08-23-2010 3:26 AM In reply to
    Bonjour Keith,
    Merci pour le compliment...! Votre Français est parfait :-) et surtout merci pour la disponibilité et la rapidité pour la réponse de samedi...
    I have took the XML file into the BeO5 and the Samsung is working with the test button (great!)
    I'm very happy that the IR Remote Code Analyzer that I have buy is Working and can help to make some files.
    What will be the next step to generate the XML file for using totally my Samsung with the BeO5.
    After i can Upload the file for the other members of Beoworld.
    Dans l'attente de vous lire,
    cordialement, Daniel.
  • 08-23-2010 5:38 AM In reply to
    Bonjour Daniel,
    Which make of IR Remote Code Analyser did you purchase ?
    To create an XML for all the buttons on your Samsung unit, you will need to capture each button and save them in seperate text files using the name of the button as the text file name. For example POWER.TXT
    From those text files we can make the XML file.
    Regards Keith....
  • 08-23-2010 6:00 AM In reply to
    Hi Keith,
    I purchase IR Remote Control Code Analyzer from NBGLIN (www.nbglin.com - http://www.nbglin.com/cpjs/dpj37.htm).
    I will capture each button and send you all the files. Is it possible to send you the same for my Sony remote and Archos AV700 ?
    Have a nice day,
    Best regards,
    Daniel.
  • 08-23-2010 10:07 AM In reply to
    Look forward to receiving your files..
    Regards Keith....
  • 09-03-2010 8:56 AM In reply to
    Hello Keith,
    I hoppe you'r all right. There is verry nice weather here in the east of France today.
    I send you the files for the different Remotes. Have a nice week,
    best regards,
    Daniel
  • 09-03-2010 1:00 PM In reply to
    Hello Daniel,
    The weather is very nice where I am near Grosetto in Italy as I am on holiday.
    I will review your file when I return which will not be until 15th Sept.
    Regards Keith....
  • 09-03-2010 3:59 PM In reply to
    Hi Keith,
    Spend nice time in your holiday.
    Best regards,
    Daniel
