Hi there,
I have a beogram 3000 built in Jan '74. It works perfectly but for the fact that it plays slightly too fast. (All the posts in this forum relate to beogram 3000's playing too slow!)
I have set the speed adjustment wheel on the side its maximum slow setting but it still plays too fast...
I've tried changing the belt for a looser one which helped, but not enough.
I've taken the back off and had a good look at the motor assy which seems to be working fine. Strangely, after i did this (which just basically involved fiddling with it - checking the lubrication was all fine) and put the thing back together, the speed was fine, it seemed the problem was solved... but then after about 10 minutes of play the speed gradually began picking up again and the problem was once again back to square one.
Does anyone out there have any suggestions? Anything ideas wuld be gratefully received...
Thanks in advance...
J
