1st March February 2012
Latest post 06-28-2007 7:33 AM by Christian. 8 replies.
06-27-2007 4:33 AM
andrewl
- Joined on 04-17-2007
- Posts 19
cleaning brushed metal on becenter 9000
Has anyone any advice on cleaning the brushed metal panels on a beocenter 9000? I would like to clean them up a bit but am not sure what to use or how to go about it.
Thanks,
Andrew
MoglesMac
- Joined on 04-25-2007
- Sweden
- Posts 109
Re: cleaning brushed metal on becenter 9000
For just quick cleaning of fingerprints and "smudges" i did use a standard windowcleaner on a dry cloth, as also mentioned in the manual under maintenance. Works very well. The advices in the link is more of a way with much dirt and scratches.
I personally used this advice on my BM5500 and i think it will be good for your 9000 since you have the same matte brushed metal as my 5500. This advice i got from the manual for BeoCenter 9000 so it would be ok.
Cheers
MoglesMac Sweden
andrewl
- Posts 19
Thanks for that. I'll try windowcleaner - is only smudges as you say. Should work werll on the glass, too.
Andrew
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
I use window cleaner (NOT the cream variety) on all the refurbs I do. Brings them up a treat including the glass. Don't put too much on or it will run into the electronics! I cannot recommend the suggested "wet and dry" treatment. The 9000 has a genuine "brushed" finish rather than the more matt effect on models such as the 5500 series and you will never be able to reproduce it.
Christian
- Copenhagen, Denmark
- Posts 626
andrewl: Thanks for that. I'll try windowcleaner - is only smudges as you say. Should work werll on the glass, too.
Andrew
If the smudges turs out to be sticky, you can try with a little toothpaste in connection with a cloth and window cleaner.
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
andrewl
- Posts 19
Thanks all for the advice. I used window cleaner - astonished at the ampount of dirt that came out from the little crevices in the brushed aluminium! And the streaks which resulted - it kept me occupied for a surprising amount of time, but now looks ace.
Christian, I'll try the toothpaste tip on the windows of my narrow boat - they'd had "Sold" signs stuck up with selotape and which left marks not removeable with white spirit or window cleaner. Toothpast, being a mild abrasive, just might do it!
Thanks,
Andrew
Christian
- Posts 626
andrewl: Thanks all for the advice. I used window cleaner - astonished at the ampount of dirt that came out from the little crevices in the brushed aluminium! And the streaks which resulted - it kept me occupied for a surprising amount of time, but now looks ace.
Thanks,
Andrew
Toothpaste on glass is not a very good idea, tried in once on sunglasses with a bad result. But it works on hard (metal) surfaces both shiny, brushed and grinded.
Page 1 of 1 (9 items)
