Latest post 06-28-2007 7:33 AM by Christian. 8 replies.
Page 1 of 1 (9 items)
  • 06-27-2007 4:33 AM
    cleaning brushed metal on becenter 9000
    Has anyone any advice on cleaning the brushed metal panels on a beocenter 9000? I would like to clean them up a bit but am not sure what to use or how to go about it.
    Thanks,
    Andrew
  • 06-27-2007 4:58 AM In reply to
    • van
    • Top 100 Contributor
    • Joined on 10-19-2006
    • Brighton, UK
    • Posts 663
    • Gold Member
    Re: cleaning brushed metal on becenter 9000
    Hi, I personally don't know but I can recommend a previous thread which may be of interest to you:
    http://forum.beoworld.org/forums/thread/9036.aspx
  • 06-27-2007 5:41 AM In reply to
    For just quick cleaning of fingerprints and "smudges" i did use a standard windowcleaner on a dry cloth, as also mentioned in the manual under maintenance. Works very well. The advices in the link is more of a way with much dirt and scratches.
    I personally used this advice on my BM5500 and i think it will be good for your 9000 since you have the same matte brushed metal as my 5500. This advice i got from the manual for BeoCenter 9000 so it would be ok.
    Cheers
    MoglesMac
    Sweden
  • 06-27-2007 6:23 AM In reply to
    Thanks for that. I'll try windowcleaner - is only smudges as you say. Should work werll on the glass, too.
    Andrew
  • 06-27-2007 8:51 AM In reply to
    I use window cleaner (NOT the cream variety) on all the refurbs I do. Brings them up a treat including the glass. Don't put too much on or it will run into the electronics!
    I cannot recommend the suggested "wet and dry" treatment. The 9000 has a genuine "brushed" finish rather than the more matt effect on models such as the 5500 series and you will never be able to reproduce it.
    Regards Graham
  • 06-27-2007 1:04 PM In reply to
    Thanks . Will do!
  • 06-27-2007 1:16 PM In reply to
    • Christian
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    andrewl:
    Andrew
    If the smudges turs out to be sticky, you can try with a little toothpaste in connection with a cloth and window cleaner.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 06-28-2007 6:35 AM In reply to
    Thanks all for the advice. I used window cleaner - astonished at the ampount of dirt that came out from the little crevices in the brushed aluminium! And the streaks which resulted - it kept me occupied for a surprising amount of time, but now looks ace.
    Christian, I'll try the toothpaste tip on the windows of my narrow boat - they'd had "Sold" signs stuck up with selotape and which left marks not removeable with white spirit or window cleaner. Toothpast, being a mild abrasive, just might do it!
    Thanks,
    Andrew
  • 06-28-2007 7:33 AM In reply to
    • Christian
    • Posts 626
    andrewl:
    Thanks,
    Andrew
    Toothpaste on glass is not a very good idea, tried in once on sunglasses with a bad result. But it works on hard (metal) surfaces both shiny, brushed and grinded.
