No, I never received a schematic. There are a lot of aging capacitors, especially in the preamp. One wouldn´t like to work on it without a schematic. Also, the S/N ratio wasn´t to great even when new. Someone on the net successfully revised the ground connections (on another B&O model, but still) which makes it even more difficult if one should try it blindly. For instance, Rogers Cadet is fitted with ECL 86´s and has a fine reputation. Best regards
