Hi techtrino,
does the lamp burn a) at full or b) at reduced brightness?
Does it turn on a) immediately (as it does when connected to a standard power switch) or does it b) light up slowly?
It your answer is a) both times, I would assume the internal regulator (triac) has a short cut and needs to be replaced.
