Latest post 07-13-2010 1:19 PM by beaker. 3 replies.
Page 1 of 1 (4 items)
  • 07-13-2010 8:09 AM
    Cleaning a slide rule Beomaster
    I want to give a couple of my Beomasters (3000 family) a bit of a clean externally and have been wondering how best to go about it. Its only to remove the dirt on the switches and face plates etc. Would some cotton buds dipped in soapy water be good or would alcohol do the job (the non drinkable type of course!) I dont want to remove the printing on the front so thought I would check first.
  • 07-13-2010 10:11 AM In reply to
    Re: Cleaning a slide rule Beomaster
    For all my B&O, I use glass cleaner (for sunglasses), it usually works great on those aluminum surfaces. I use is for all my Beomasters (including a Beomaster 4400 :), Beograms, Beocords and even Beovox speakers. But just be sure that the type of cleaner you use doesn't remove the lettering and printings on your 3000/4000/4400, I have been using denatured alcohol for my Beomaster 6000, but not sure if the 3000 family printing can handle it.
    -Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 07-13-2010 11:41 AM In reply to
    I use cotton buds and soapy water. Particular care should be taken with Beolab 5000s.
  • 07-13-2010 1:19 PM In reply to
    Peter :
    Thanks for that. Its mainly going to be done to a newly aquired BM4400 (pics to come soon!). I wouldnt do anything to my 5000 as there are already bits that have worn off so I will leave that one alone.
