I try to figure out how to setup a media center in a way described below, but do not find a solution:
What I would like to do:
Watch TV, Record TV, Watch DVD, Listen to MP3
My first thought was to use MacMini in combination with EyeTV Hybrid and send the signal to the BeoVision 8. In this way I would be able to use the EyeTV software to watch and record. I could also play music via Frontpage etc.
Tested today but with a problem: EyeTV can not decode the digital channels (DVB-C, Provider Kabel Deutschland) so this would need an additional receiver and I would have to control this receiver and not the MacMini.
Is there a other way to setup this system? ie using the beovision 8 (does it support CI+?) and stream the TV signal to the macMini and control the macMini with the beo4???
I am not sure if this is enough information, but maybe somebody else configured his system in the way beovision 8 and macMini trasnfers the signals in both ways??
BR, Alex
