Latest post 06-29-2010 6:36 AM by Tillquist. 7 replies.
Page 1 of 1 (8 items)
  • 06-25-2010 3:54 PM
    • dueno
    • Top 500 Contributor
    • Joined on 04-29-2007
    • bordeaux
    • Posts 147
    what's new in the 3.87 version?
    Do you know where find it?
    never explain never complain
  • 06-25-2010 7:05 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: what's new in the 3.87 version?
    dueno:
    New in 3.87
    - Load previous local versions (going back to a working config)
    - Support for new Beo4 (type 1710) w. cursor control
    - Drag and drop of template logos
    - more than 200 PUC-Sources updated with cursor control
    - PUC-Sources are sorted by type and manufacturer
    - Correct channel step inside channels menu
    - Navigate to "Zones"
    - Navigate to "Setup mode"
    - Updated "Help"
    & some bug fixes
  • 06-26-2010 3:21 AM In reply to
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    Vienna:
    Interesting. Can you explain a bit more on how this cursor control works?
    What I would like: I operate my PS3 over PUC. Works fine except internet, the up/down buttons move from link to link only. This makes some pages hard to read. What I would like is to be able to scroll down. Is this where "cursor control" would help?
    Thanks for the info!
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 06-26-2010 3:50 AM In reply to
    • Vienna
    • Posts 712
    Bieele:
    Similar to the Beo5 ...
    Many Set Top Boxes have/need separate buttons/commands for "UP" and "DOWN" (e.g. change channels)
    and "NAVIGATION" inside of menues.
    The new Beo 4 offers these possibilities ...
    More info : http://forum.beoworld.org/forums/p/33744/277784.aspx#277784
  • 06-26-2010 6:14 AM In reply to
    • Bieele
    • Netherlands
    • Posts 339
    Thanks for the info.
    And with the new Beo5 SW we can also use this for the Beo5?
    Bieele
  • 06-27-2010 7:50 AM In reply to
    • Vienna
    • Posts 712
    All recent BeoVision TVs offer in the setup menue an additional paragraph "Beo4 Setting"
    offering the choice: "Navigation button" or "No navigation button" regarding the type
    of Beo4 to be used.
    Older TVs will need a SW update to get "Type 1710" ready.
  • 06-28-2010 9:22 AM In reply to
    • dueno
    • bordeaux
    • Posts 147
    where can i found this new version?
  • 06-29-2010 6:36 AM In reply to
    Yes, that version will I allso like to have some day Smile
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
