dueno:
what's new in the 3.87 version?
New in 3.87
- Load previous local versions (going back to a working config)
- Support for new Beo4 (type 1710) w. cursor control
- Drag and drop of template logos
- more than 200 PUC-Sources updated with cursor control
- PUC-Sources are sorted by type and manufacturer
- Correct channel step inside channels menu
- Navigate to "Zones"
- Navigate to "Setup mode"
- Updated "Help"
& some bug fixes
