Radio in Beomaster 6500, does not remember their station after store, ask for your help see why. Thanks
There's a lithium cell (battery) inside the processor casing that holds the info in the memory.It's soldered in and the module must be handled in anti-static environment.Best replaced by a trained tech guy but shouldn't be an expensive repair.
OK, thanks U very much
Hi Martin!I opened beomaster 6500 but did not find lithium cell (battery) inside, you can specify it fears me where on my picture below to replace the lithium cell.Thanks U so muchHacoi
check the microprocessor board ... vertically mounted at the front ... shielded front and back
neil
Inside the processor metal shielding and soldered to the board.Actually to be opened only by a trained tech guy in antistatic environment.Remember to reset the NVRAM after replacing the cell.
Hi Martin and neil !
You can be mapped and guidance on how to open photos instead of me?
Thanks you,
Sincerely.
