Latest post 06-22-2010 9:14 PM by Hacoi. 6 replies.
Page 1 of 1 (7 items)
  • 06-15-2010 3:31 AM
    • Hacoi
    • Not Ranked
    • Joined on 06-15-2010
    • Vietnam
    • Posts 13
    Radio in beomaster 6500??
     Radio in Beomaster 6500, does not remember their station after store, ask for your help see why. Thanks
  • 06-15-2010 10:53 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Radio in beomaster 6500??
    There's a lithium cell (battery) inside the processor casing that holds the info in the memory.
    It's soldered in and the module must be handled in anti-static environment.
    Best replaced by a trained tech guy but shouldn't be an expensive repair.
  • 06-15-2010 8:54 PM In reply to
    • Hacoi
    • Not Ranked
    • Vietnam
    • Posts 13
    OK, thanks U very much
  • 06-22-2010 10:40 AM In reply to
    • Hacoi
    • Not Ranked
    • Vietnam
    • Posts 13
    Hi Martin!
    I opened beomaster 6500 but did not find lithium cell (battery) inside, you can specify it fears me where on my picture below to replace the lithium cell.
    Thanks U so much
    Hacoi
  • 06-22-2010 4:22 PM In reply to
    check the microprocessor board ... vertically mounted at the front ... shielded front and back
    neil
  • 06-22-2010 4:45 PM In reply to
    • Dillen
    • Posts 5,008
    Inside the processor metal shielding and soldered to the board.
    Actually to be opened only by a trained tech guy in antistatic environment.
    Remember to reset the NVRAM after replacing the cell.
  • 06-22-2010 9:14 PM In reply to
    • Hacoi
    • Not Ranked
    • Vietnam
    • Posts 13
    Hi Martin and neil !
    You can be mapped and guidance on how to open photos instead of me?
    Thanks you,
    Sincerely.
