Update... Using the 0/10/560 entry solved the problem I had w/ the panel turning off.
The startup issue persists. I have set the BS1 to having a Zektor switch, which I read somewhere? would trick the BS1 into looking at the component connections first. I have not had a chance to see if this works yet w/o the Zektor in place.
UD: Couldn't get it to work, so I moved on to installing the Zektor.
I have also purchased a Zektor switch which I will install after testing the above. From what I have read, the Zektor seemingly solves these problems.
UD: Installed the Zektor... it seems to work OK manually, but my Beo4 could not control it.
No improvement on startup -still had to do the MENU trick for now.
I will probably stick w/ the lazy route and use my Logitech where I can program the trick in.
If anything changes I will let you know.
