Latest post 06-22-2010 6:03 AM by northswede. 5 replies.
Page 1 of 1 (6 items)
  • 05-09-2010 9:52 AM
    • Emil
    • Top 500 Contributor
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    BS5 and speakers connected to BV7
    Dear all,
    Is it possible to connect the BS5 to a BV7, speakers connected to BV7, and still have audio from the speakers without having to push PC on the Beo4? I used to have a BS3200 connected to the system as well and then there was no problem at all. Now there is is no audio unless I activate the PC function of the BV7. BS5 is registered as audio master and BV7 as videomaster with speakers connected (can't remember which option).
    Problem will be solved once I get the chance to connect the entire system again but for now it would be great if I could get audio from the speakers without pressing PC since that means I will get a picture on the screen as well.
    Inflagrante
  • 05-12-2010 11:52 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: BS5 and speakers connected to BV7
    If your BS5 is set to audiomaster and A.OPT 0, the BV7 to V.OPT 2 it should work pressing N.MUSIC or N.RADIO. Should even work with a BS3200 connected if your BS5 is set to NO AUDIOMASTER - works in my setup with BS9000.
    Hope this helps.
    Stefan
  • 05-14-2010 1:50 PM In reply to
    • Emil
    • Stockholm, Sweden
    • Posts 98
    ...and it works like a charm. Many thanks for your assistance.
    /Emil
    Inflagrante
  • 05-16-2010 4:27 PM In reply to
    • stefan
    • Posts 1,733
    You `re welcome - enjoy.
    Stefan
  • 05-26-2010 5:34 AM In reply to
    • MikaelB
    • Joined on 04-17-2007
    • Herning, Denmark
    • Posts 191
    You should also be able to set the BeoSound 5 to react to CD and RADIO, in this way you don't need to press LIST first.
    /MikaelB
  • 06-22-2010 6:03 AM In reply to
    • northswede
    • Not Ranked
    • Joined on 04-29-2010
    • Stockholm, Sweden
    • Posts 32
    MikaelB:
    /MikaelB
    If I remember correctly, You have to set the BeoSound to Audiomaster before you can configure CD and Radio to replace N.Music and N.Radio.
    Current collection: BeoVision 7-40 mk III, BeoLab 7-4, BeoLab 3 and BeoSound/BeoMaster 5.
    Seriously, it's a beautiful package of excellent and awesomeness!
