Dear all,
Is it possible to connect the BS5 to a BV7, speakers connected to BV7, and still have audio from the speakers without having to push PC on the Beo4? I used to have a BS3200 connected to the system as well and then there was no problem at all. Now there is is no audio unless I activate the PC function of the BV7. BS5 is registered as audio master and BV7 as videomaster with speakers connected (can't remember which option).
Problem will be solved once I get the chance to connect the entire system again but for now it would be great if I could get audio from the speakers without pressing PC since that means I will get a picture on the screen as well.
