Iam utilizing the powered speakers that came with the unit. They power up and the lights go from red to green just as if they always have. but no sound. The Beosystem mute button works, the volume levels read as I raise the volume, but no output. The CD spins, the record on the turntable spins, the radio stations appear on the readouts, but no output. I ask the forum because I feel like I have done something stupid and dont know what it is. I have not moved disconnected or in any way altered the set up from the last time I used it.
The green memory set light is on when the unit is in standby. I reset the time and there is no memory set in the unit. The green memory light goes out when I activate the CD, Radio Etc. I cant get the green memory light to turn off as per the unit instructions ( " when unit is in standby, press mute ) but all the remotes continue to function properly.
Mr. Bob
