Latest post 04-25-2010 10:59 AM by Vienna. 4 replies.
Page 1 of 1 (5 items)
  • 04-22-2010 6:50 PM
    BeoSystem 2500 Remotes
    Besides the BeoLink 1000 & 5000, are there any B & O remotes that will work with the BeoSystem 2500?
  • 04-22-2010 10:59 PM In reply to
    Re: BeoSystem 2500 Remotes
    Welcome to BeoWorld!
    The least common denominator in "later" Beo is the BL1000...
    If it works w/ at least a BL1000... then it will work w/ any of the later remotes in some form or fashion.
    Cost vs. Performance... the BL1000 is gold.
    • B&o bottle opener
  • 04-23-2010 6:41 AM In reply to
    Beolink 1000, Beolink 5000, Beo4 work perfectly, Beo5 also works
  • 04-25-2010 9:28 AM In reply to
    • AT
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Posts 187
    IMHO all later remotes then the BL1000 will work perfectly with the BS2500.
    Also, if the system is an early one, then both the BL5000 and the BL7000 will work with it as a two way remote, which is a real fun :)
    Please note: The BL2500's RDS system will not transfer the station name to the remote, the only system can do it is the BL7000.
  • 04-25-2010 10:59 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    All BeoLink remotes mentioned in former postings will work for daily use.
    ! But !
    You'll need a 2-way remote like BL5000 or BL7000 to access timer programming (record-, play- and standby-timers)
