Did this years ago!
As far as I remember:
- you unscrew / dissasemble and open the clamp mounted to the baseplate
- shorten the tube on the BOTTOM end!
!! On the top end you will cut away the cable entry and the bushing/insert for "plugging in" the BV/BC1 !!
!! Don't forget to protect the aluminium tube during clamping in the vice !!
