Latest post 04-18-2010 4:35 PM by hebo. 5 replies.
Page 1 of 1 (6 items)
  • 04-15-2010 2:44 PM
    • hebo
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Sweden
    • Posts 305
    It´s a sin - I know, but....
    I wonder if anyone knows if it is difficult to shorten the pole of a high floor stand for Beovision 1?
    I know it is a shame, but I need it to be 10 cm shorter to fit my place.
    Anybody have a pic of the end of the pole thats goes into the BV?
     BV10
  • 04-15-2010 3:31 PM In reply to
    Re: It´s a sin - I know, but....
    Not sure it looks that easy! I have put the fitting manual for the high stand on site in the BV1 service manual area.
  • 04-15-2010 4:22 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    It's been done plenty of times - i can't remember the last BV1/BC1 High Stand i had in stock that was the original height!
    Lift up the aluminium disc trim and you'll see the pole is clamped in.  Undo the allen bolt, free the pole, then take it to a metalworking engineers shop who'll precision cut it to your desired height - bingo!
    Lee
    Smile
  • 04-15-2010 4:46 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Did this years ago!
    As far as I remember:
    - you unscrew / dissasemble and open the clamp mounted to the baseplate
    - shorten the tube on the BOTTOM end!
    !! On the top end you will cut away the cable entry and the bushing/insert for "plugging in" the BV/BC1 !!
    !! Don't forget to protect the aluminium tube during clamping in the vice !!
  • 04-16-2010 2:51 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Vienna:
    Did this years ago!
    Spot on :)
  • 04-18-2010 4:35 PM In reply to
    • hebo
    • Sweden
    • Posts 305
    Thank you all,
    now I know how to do,
    I love this place......Big Smile
     BV10
