Just a theory,and I welcome criticism.
I have not yet commited to the inevitable purchase of a new soundsmith cartridge.I have just one functional MMC20EN that does triple duty between my Beocenter 7000,beogram 3400,and recently,my new beogram 4004.The cartidge suspension in worn.the stylus is a bit offset from center when at rest,at play on the BC7000 and BG3400 the pull of the arm causes the stylus to pull even farther from center.The sound of these two radial decks is fair but distorts a bit on complex passages.It appears that the stylus and iron assembly,being pulled off center is being biased on one side,and distorting in passages of high modulation.
Now on my new 4004,the sound is much better,and I noticed no extra pull of the stylus (beyond it's at-rest offset).I suspect this is due to the tonearm practically free floating and having substantially less mass than the radial TTs.
My question is this:Have I gotten new life(or extended life),and better sound out of my slightly worn pickup by installing it on the tagential deck?Also, is a cartridge doing years of service on a tangential deck likely never to wear out like this, biased to one side as on the radial deck?
Paul
