Hi all,
I am currently trying to get some MACROS working on my BEO5 but it doesn't seem to work.
My setup is like this : I have a BEOVISION 3 with STB module and attached a SAMSUNG B270R to it. All works well, but since I own a BEO5 and config software, I was thinking to give some buttons of the original remote to my BEO5.
One of them for example the the EPG button. I can shortcut with the BEO5 by pressing : GO -> 9 which will show me the EPG page of the SAMSUNG. But I want this under one button.
I am using the CONFIG TOOL  ver 3.57 and thisone comes with a PUC source for the samsung. However, the special buttons like Program Guide do NOT work properly.
I read the writeup by Keith on http://195.173.140.100/Beoworld/Beo5WebSite/FAQ.htm that mentioned:
"The Beo5 Configuration
				  Tool in-correctly sets up DVB-T icons and their associated "IR"
codes. All
				  DVB-T command IR strings must start with TV:EXIT followed by
TV:CNTL_WIND
				  followed by 450 milli second delay followed by the command such as
 TV:CIFFER_1
				  for "Channel List" If you do not add the delay before the command
then the TV
				  will switch channel numbers instead."
I put the following string in it:
0:000:TV:EXIT
0:000:TV:CNTL_WIND
Delay: 450ms
0:000:TV:CIFFER_9
This doesn't work and doesn't appear to do anything at all.  Where did I fail?
Thanks all for the help,
Peter.
