Latest post 03-19-2010 6:58 AM by Dapper. 2 replies.
Page 1 of 1 (3 items)
  • 03-18-2010 12:49 PM
    Can't write proper macros for my STB attached Samsung B270R
    Hi all,
    I am currently trying to get some MACROS working on my BEO5 but it doesn't seem to work.
    My setup is like this : I have a BEOVISION 3 with STB module and attached a SAMSUNG B270R to it. All works well, but since I own a BEO5 and config software, I was thinking to give some buttons of the original remote to my BEO5.
    One of them for example the the EPG button. I can shortcut with the BEO5 by pressing : GO -> 9 which will show me the EPG page of the SAMSUNG. But I want this under one button.
    I am using the CONFIG TOOL  ver 3.57 and thisone comes with a PUC source for the samsung. However, the special buttons like Program Guide do NOT work properly.
    I read the writeup by Keith on http://195.173.140.100/Beoworld/Beo5WebSite/FAQ.htm that mentioned:
    "The Beo5 Configuration Tool in-correctly sets up DVB-T icons and their associated "IR" codes. All DVB-T command IR strings must start with TV:EXIT followed by TV:CNTL_WIND followed by 450 milli second delay followed by the command such as TV:CIFFER_1 for "Channel List" If you do not add the delay before the command then the TV will switch channel numbers instead."
    I put the following string in it:
    0:000:TV:EXIT
    0:000:TV:CNTL_WIND
    Delay: 450ms
    0:000:TV:CIFFER_9
    This doesn't work and doesn't appear to do anything at all.  Where did I fail?
    Thanks all for the help,
    Peter.
  • 03-19-2010 6:38 AM In reply to
    Re: Can't write proper macros for my STB attached Samsung B270R
    According to the latest version of the Samsung DCB-B270R/Z then EPG button is like you see below... (maybe it is because its an old version in your IC)
    To activate one of the overlay functions you need to make a macro like this:
    0:000:TV:PLAY
    Delay 450ms
    0:000:TV:CIFFER_2
    BEO4 ORIGINAL
    GO Select
    GO (long) Guide
    EXIT Return
    UP Up
    DOWN Down
    LEFT Left
    RIGHT Right
    RED RED
    GREEN GREEN
    YELLOW YELLOW
    BLUE BLUE
    MENU/GO
    1 MENU
    2 GUIDE
    3 PG +
    4 PG -
    5 TEXT
    6 AUDIO
    7 ALT
    8 TV/RADIO
    GO
    GO+0 Power
    GO+UP ChUp
    GO+DOWN ChDown
  • 03-19-2010 6:58 AM In reply to
    Guffas,
    thanks!! This works Superb! I will make the proper modifications to the other buttons in this way too.
    Thanks again,
    Peter.
