Can anyone please help? I need to change a damaged back glass strip on a Beocenter 9000. I am not certain how to remove it. Some time ago I had a problem with the CD door slide and I think I repaired this by looking at the Service manual in this site. I am sure that the assembly diagram I used had details of the back glass panel fixing also but I can't find a hard copy in my notes.
I have tried to look at the same diagram again but cannot find it! The entry states it is not available. I have a recollection that there is a securing screw at one end going upwards into a carrier. The carrier has a series of "hooks fitting into slots on the main chassis. With the screw removed the carrier and glass panel can be slide to the side about 1cm freeing these hooks so that it can be lifted up.
Am I on the right lines or is it all a very detailed figment of my imagination ??
Many thanks
John
