Latest post 03-08-2010 3:35 PM by John. 5 replies.
Page 1 of 1 (6 items)
  • 03-08-2010 10:03 AM
    • John
    • Not Ranked
    • Joined on 09-20-2009
    • BRISTOL UK
    • Posts 62
    • Silver Member
    Back Glass panel on Beocenter 9000
    Can anyone please help?  I need to change a damaged back glass strip on a Beocenter 9000. I am not certain how to remove it. Some time ago I had a problem with the CD door slide and I think I repaired this by looking at the Service manual in this site. I am sure that the assembly diagram I used had details of the back glass panel fixing also but I can't find a hard copy in my notes.
    I have tried to look at the same diagram again but cannot find it! The entry states it is not available.  I have a recollection that there is a securing screw at one end going upwards into a carrier. The carrier has a series of "hooks fitting into slots on the main chassis. With the screw removed the carrier and glass panel can be slide to the side about 1cm freeing these hooks so that it can be lifted up.
    Am I on the right lines or is it all a very detailed figment of my imagination ??
    Many thanks
    John
  • 03-08-2010 10:26 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Back Glass panel on Beocenter 9000
    Hi John,
    If it's the same as the BC9500, that service manual is available on here. When you have the unit open and hinged forward exposing the insides looking in from the back the screws are located on the right hand side of the lid in each corner. Undoing either enables the frame/glass to slide to the left (standing at the rear of the unit) and unhook.
    See part 5 of the BC9500 service manual section 6-6
    Just be careful the other glass panel doesn't fall out when you put the lid upright - the glue will probably be perished if it hasn't been repaired before.
    Steve
    If you think nobody cares, try missing a couple of payments.
  • 03-08-2010 11:40 AM In reply to
    • John
    • Not Ranked
    • BRISTOL UK
    • Posts 62
    • Silver Member
    Steve many thanks. It seems my memory was not inventing things. I can't remember using the 9500 service sheets but that is what I must have done.
    I don't feel as apprehensive now so can go ahead.
    Regards
    John
  • 03-08-2010 1:40 PM In reply to
    Dont bother opening the Beocenter up as there is absolutely no need.
    Simply stand the Beocenter on it's back edge! It will stand quite happily. The screws that you remember are in the left hand corners.
    Remove one or both and turn the beocenter back into it's flat position. Now just slide the glass /frames 1cm to the right and you can lift the glass off.
    Regards Graham
  • 03-08-2010 1:47 PM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    It hadn't occurred to me you could get access to them so easily - or the Beocenter would stand on it's back! Great stuff.
  • 03-08-2010 3:35 PM In reply to
    • John
    • Not Ranked
    • BRISTOL UK
    • Posts 62
    • Silver Member
    Thank you both. This is brilliant, I only need to remove one panel so it should all be easy. I now know that I can use the 9500 diagrams if I have any further problems.
    It is amazing how quickly BeoWorld can help with odd problems
