Latest post 03-14-2010 11:44 AM by Dillen. 5 replies.
Page 1 of 1 (6 items)
  • 03-06-2010 1:34 PM
    • Ben
    • Top 500 Contributor
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    Beocenter 3500 / Beomaster 3000 Idle current trim pot
    I've been given a Beocenter 3500 that i'm trying to get working as it should.
    Someone's been in there before and replaced the idle current trimpot for the right channel with one of completely the wrong value, and hence that side is idling at 1 amp!
    The original 250 ohm linear pot is not stocked at my usual sources, the nearest available is 200 ohm - would this be a good substitute?
    Ben
  • 03-07-2010 8:07 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 3500 / Beomaster 3000 Idle current trim pot
    Yes, 200 or 220 Ohm will be acceptable.
  • 03-09-2010 4:34 AM In reply to
    • Ben
    • Taunton, UK
    • Posts 131
    • Silver Member
    Thanks Martin, i'll get a couple ordered and we'll see if I can get it living again.
  • 03-09-2010 6:18 AM In reply to
    • Dillen
    • Posts 5,008
    I can supply correct 250 ohm trimmers if everything else fails.
  • 03-09-2010 6:51 AM In reply to
    • Ben
    • Taunton, UK
    • Posts 131
    • Silver Member
    I'll bare that in mind if I can't get the 200 ohm trimmers to set the idle correctly.
    How about a belt for the 3500's turntable?
  • 03-14-2010 11:44 AM In reply to
    • Dillen
    • Posts 5,008
    You have a PM regarding belt.
