I've been given a Beocenter 3500 that i'm trying to get working as it should.
Someone's been in there before and replaced the idle current trimpot for the right channel with one of completely the wrong value, and hence that side is idling at 1 amp!
The original 250 ohm linear pot is not stocked at my usual sources, the nearest available is 200 ohm - would this be a good substitute?
Ben
