Latest post 02-23-2010 7:54 AM by Dillen. 1 replies.
Page 1 of 1 (2 items)
  • 02-23-2010 5:16 AM
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    BeoGram 4002 ToneArm Zero Balancing
    Hi all,
    I'm working on a BG4002, and need some clear instructions in English.  My original SM is in German, and my German is OK, but not to the technical level in the particular steps described in the manual.
    Has anybody done this successfully before, and can give me step-by-step instructions to continue?
    I've got this far that the centre bolt below adjusts something, but I'm not sure what to be looking for, and whether the MMC cartridge must be mounted or not, to give weight to the tonearm.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 02-23-2010 7:54 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BeoGram 4002 ToneArm Zero Balancing
    Obviously, the cartridge should be mounted when adjusting or the weight of the cartridge would have to be added
    to what is set on the dial, making it impossible or at least very confusing to get right.
    It's described in the service manual, can be download'ed by silver and gold members. Well
    worth the small membership fee and Beoworld would be thankful for your support.
    The manual found there is in english and the static balance is found on page 4-4.
