Hi all,
I'm working on a BG4002, and need some clear instructions in English. My original SM is in German, and my German is OK, but not to the technical level in the particular steps described in the manual.
Has anybody done this successfully before, and can give me step-by-step instructions to continue?
I've got this far that the centre bolt below adjusts something, but I'm not sure what to be looking for, and whether the MMC cartridge must be mounted or not, to give weight to the tonearm.
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
