Latest post 02-06-2010 3:42 PM by Opman. 1 replies.
Page 1 of 1 (2 items)
  • 02-06-2010 3:27 PM
    • newbeo
    • Not Ranked
    • Joined on 01-14-2010
    • Posts 6
    Beocenter 8000 Speakers?
    HI, can anyone tell me if active speakers can be used with a beocenter 8000, I do not think it has powerlink socket? Thanks.
  • 02-06-2010 3:42 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Beocenter 8000 Speakers?
    Hi
    BeoCenter 8000 doesn't have powerlink sockets but you can still use Active speakers. You just need the appropriate adaptor cable depending on which Active speakers you want to use. You connect to the standard two pin din speaker sockets.
    Opman
