HI, can anyone tell me if active speakers can be used with a beocenter 8000, I do not think it has powerlink socket? Thanks.
Hi
BeoCenter 8000 doesn't have powerlink sockets but you can still use Active speakers. You just need the appropriate adaptor cable depending on which Active speakers you want to use. You connect to the standard two pin din speaker sockets.
Opman
