BarryNI:
Now that we have lost analogue TV in our area, is there a freeview or freesat module available for the Avant?
The recommended box used to be made by Panasonic (TU-30???). Best to look at your STB list and then search for a compatible freeview box.
If you haven't got the STB module then you need to sound out your dealer. It's now getting to the point on the second-hand CRT market that it will soon be cheaper to get a later Avant TV with the latest module and chip rather than buy them new and have them fitted to an old set! If you've got a module with an old chip then the most universal approach will be to use a Skybox for freesat as the Skyboxes seem to have been listed on all STB menus and the codes are still the same now as they were 5 or 10 years ago.
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
