Latest post 02-03-2010 6:50 AM by BarryNI. 2 replies.
Page 1 of 1 (3 items)
  • 02-02-2010 10:58 AM
    Avant 32 digital module
    Now that we have lost analogue TV in our area, is there a freeview or freesat module available for the Avant?
  • 02-02-2010 1:06 PM In reply to
    Re: Avant 32 digital module
    BarryNI:
    The recommended box used to be made by Panasonic (TU-30???). Best to look at your STB list and then search for a compatible freeview box.
    If you haven't got the STB module then you need to sound out your dealer.  It's now getting to the point on the second-hand CRT market that it will soon be cheaper to get a later Avant TV with the latest module and chip rather than buy them new and have them fitted to an old set!  If you've got a module with an old chip  then the most universal approach will be to use a Skybox  for freesat as the Skyboxes seem to have been listed on all STB menus  and the codes are still the same now as they were 5 or 10 years ago.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 02-03-2010 6:50 AM In reply to
    Many thanks Graham, I have been using a SKY box, but as the set was sourced from Europe, there is no STB module fitted.  I will check with my dealer but suspect that it is time for the set to go.
