Latest post 06-22-2007 2:35 AM by marcus_m. 4 replies.
Page 1 of 1 (5 items)
  • 06-18-2007 11:00 AM
    • rw
    • Not Ranked
    • Joined on 06-15-2007
    • Posts 1
    Cabling to a Beolab 3500
    Hello All, (and help!)
    I've been asked by a friend to help with his beosound 9000 sound system. He has 3no Beolab 3500 speakers wired in Cat5e (4 pair) cable and can't get any sound through them. They all have power from a seperate source. I've tried fitting the Beolink connectors to the Cat5e and the speakers are responding to the remote controle, but still no sound.
    Am I missing anything obvious? Can the Cat5 be 'adapted' to work?
    Any input would be greatly appreciated.
    Many Thanks
    rw
    Filed under:
  • 06-18-2007 11:16 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Cabling to a Beolab 3500
    Are you positive it's wired correctly? Check this wiring diagram:
    http://beotech.co.uk/wiring4.htm
    Also, I believe Cat5 cable isn't appropriately shielded. You may notice a drop in sound quality or even issues with communicating. Have never actually wired an ML cable so I couldn't tell you what the side-effects are of using the wrong cable...
     Weekly top artists:
  • 06-18-2007 12:01 PM In reply to
    CAT5 cable is not suitable, whilst I am sure some people have used it particularly for short runs it is suited to all signals being balanced pairs of signal wires, Masterlink is not. I strongly suggest using the correct type of ML cable.
    Regards Keith....
  • 06-21-2007 7:58 PM In reply to
    I don't think cat5 is shielde at all, so you don't hav ground connection if am not right, you ned to schortcut white/blue and pink to get down to 8 wire. and chek your wireing
    But don't work whit no ground
    ML is a balanced signal
  • 06-22-2007 2:35 AM In reply to
    My whole house is wired with Cat7 cable and it works as the original ML cable (only much much cheaper). The Cat5e only has a foil shield, which is not sufficient for the ground of the power supply. Another drawback of Cat5 cable is, that the pairs are not shielded individually. Therefore you could hear any command in the speakers :(
    Try to run an extra cable for the ground, then it should work, but not perfect!
