My whole house is wired with Cat7 cable and it works as the original ML cable (only much much cheaper). The Cat5e only has a foil shield, which is not sufficient for the ground of the power supply. Another drawback of Cat5 cable is, that the pairs are not shielded individually. Therefore you could hear any command in the speakers :(
Try to run an extra cable for the ground, then it should work, but not perfect!
