I tried everywhere to get replacements having been told B&O no longer stock them and the German manufacturer no longer produced them. After doing some research I found they were available from a Chinese manufacturer via CPC distributers in the UK. They are the same apart from the connection "tags" which are located in a different position which I modified to the original location. The overall size and mountings are the same as the original units. The price from CPC is 11.17 each +VAT which I think you will find is considerably less than the B&O units when they were available.
Ron
