Latest post 01-31-2010 6:37 AM by Beofile7. 4 replies.
Page 1 of 1 (5 items)
  • 01-16-2010 8:47 AM
    MX 3500 speakers
    Does anyone know if the loudspeakers in an MX3500 are still available or an equivalent or a repair kit available? Dreaded foam rot!
  • 01-16-2010 12:14 PM In reply to
    Re: MX 3500 speakers
    I tried everywhere to get replacements having been told B&O no longer stock them and the German manufacturer no longer produced them. After doing some research I found they were available from a Chinese manufacturer via CPC distributers in the UK. They are the same apart from the connection "tags" which are located in a different position which I modified to the original location. The overall size and mountings are the same as the original units. The price from CPC is 11.17 each +VAT which I think you will find is considerably less than the B&O units when they were available.
    Ron
  • 01-20-2010 10:19 AM In reply to
    Hi Ron
    That sounds interesting. I don't suppose you have a product number or something else to go on as they have many many units on their website? Any loss in sound quality with them?
  • 01-30-2010 5:48 AM In reply to
    • Trigi
    • Not Ranked
    • Joined on 01-29-2010
    • Ry, Denmark
    • Posts 21
    • Gold Member
    Hi Boefile7
    I got the speakers u need. Where do u live?
    Best regards
    Trigi (Denmark)
  • 01-31-2010 6:37 AM In reply to
    Hej Trigi
    What do you have? Are they from an old MX3500? I have only just got home so haven't had a chance to source replacement units yet.
    I am in Stockholm!
