Latest post 01-15-2010 2:07 PM by cooldude. 3 replies.
Page 1 of 1 (4 items)
  • 01-15-2010 6:58 AM
    Beolink passiv without IR eye connected.Need your help
    Hi everybody
    I have a beolink passiv but I don't have the IR eye.I tried to test it but I hear no sound.I plug a Masterlink cable into a beosound Ouverture and one CX 100 passiv speaker.
    I thought that the beolink passiv could be used like the MCL2P without an IR eye.
    PLease, if you have a beolink passiv unplug the IR eye and tell me if you hear any sound.
    Thanks a lot
    Best regards
    OLivier
  • 01-15-2010 8:06 AM In reply to
    Re: Beolink passiv without IR eye connected.Need your help
    If you use Masterlink connection then you MUST use the IR eye.
    To use without the IR eye you need to use a fully wired (Mk2) powerlink cable.
    Regards Graham
  • 01-15-2010 9:19 AM In reply to
    Hi Graham
    Thank you very much for your prompt answer.
    I have tried with a powerlink cable but it was in bad condition, I tried with an other one and it works perfectly.
    Have you ever tried to use the other kind of IR eYe (the rectangular one) with a beolink passive ?.
    I would like to use this beolink passive with an b&o IWS 200 speaker and there is a space inside its cabinet for the flat IR eye not the round.
    THanks in advance for your help
    Regards
    Olivier
  • 01-15-2010 2:07 PM In reply to
    olvisab:
    Hi Graham
    Regards
    Olivier
    You indeed need a powerlink cable for use without IR eye
    The old rectangular ones work. Though there are several version of them.
