Hi Graham
Thank you very much for your prompt answer.
I have tried with a powerlink cable but it was in bad condition, I tried with an other one and it works perfectly.
Have you ever tried to use the other kind of IR eYe (the rectangular one) with a beolink passive ?.
I would like to use this beolink passive with an b&o IWS 200 speaker and there is a space inside its cabinet for the flat IR eye not the round.
THanks in advance for your help
Regards
Olivier
