Who can tell me what is inside the external ir-"sensor" which can be used on the bm7000 for outofthecabinet usage ??
part no 8087018
nitro2
It is like the MCL IR transceiver but without the buttons.
Do you have any info on the internal parts of the sensor ??
i imagine a small pcb with some components , but which ???
might be easier to pick up a MCL extra speaker kit,and connect your main speakers to this?Use the sensor with the kit to operate the Beomaster.
