Hi:
I believe that you will need a phono pre-amp to connect a turntable to a modern amp without a phono socket. Cheap ones are available from Maplin but they do "exactly what it says on the tin" and are therefore quite plasticy:
http://www.maplin.co.uk/Module.aspx?ModuleNo=28732
NAD do a slightly more expensive one (although I have been told they come in cheaper than this):
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1441
Pro-ject do a more expensive one.
I believe this is why you are not hearing anything from source (the beogram). Be aware that early recordings will sound ery weird played through a surround setup.
Hope this helps
Graham
PS You may want to wait and see if anyone confirms or refutes my advice as I am only guessing that this is what you need.
