Latest post 12-28-2009 10:06 AM by R Patton. 2 replies.
Page 1 of 1 (3 items)
  • 12-28-2009 1:09 AM
    new acquisition
    I just acquired a Beogram 3400 turntable from a friend of mine.  I tried to hook it up to my Sony Surround system, but can't get any audio music coming out.  Any suggestions as to what I need to listen to my old vinyls?
  • 12-28-2009 5:54 AM In reply to
    Re: new acquisition
    Hi:
    I believe that you will need a phono pre-amp to connect a turntable to a modern amp without a phono socket. Cheap ones are available from Maplin but they do "exactly what it says on the tin" and are therefore quite plasticy:
    http://www.maplin.co.uk/Module.aspx?ModuleNo=28732
    NAD do a slightly more expensive one (although I have been told they come in cheaper than this):
    http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1441
    Pro-ject do a more expensive one.
    I believe this is why you are not hearing anything from source (the beogram). Be aware that early recordings will sound ery weird played through a surround setup.
    Hope this helps
    Graham
    PS You may want to wait and see if anyone confirms or refutes my advice as I am only guessing that this is what you need.
  • 12-28-2009 10:06 AM In reply to
    Re: new acquisition
    If a pre amp is what you need you might also inquire here (US source).
     http://www.phonopreamps.com/
