Could someone who has the config tool software please PM me. . .
THanks
MJM
I'm ready for something new that I actually want to buy!
google is your friend "peter pan B&O beo5 config HIFI4ALL.DK Forum"
Cheers
JK
That shows some "problems" when completed. . .
any ideas?
thanks
also. . does it require a password?
mjmedlo: That shows some "problems" when completed. . . any ideas? thanks also. . does it require a password?
No
http://tv4play.se/nyheter/lokala_nyheter/halland?videoId=1.645093
I'm assuming "Work Offline" is the right way to tinker around with the
BEO5 software?
Yes - otherwise you need a B&O log in, which is not readily available.
Thank you.. .
I'm assuming that nothing is really available until you connect a beo5 to the software correct?
I don't have any kind of options whatsoever . . (haven't connected the beo5 yet)
Is there any type of manual for the software?
Hi@ all
the Software to download is the 3.00.2 version and not the 3.23. Does anybody know where to download the 3.23 and what the difference is?
Is the newfirmware automatically installed although offline?
I have 2.20 and is it worth upgrading? Do I have to programm new?
Best regards Oliver
How and where do you "upload" the xml files?
OKF: Hi@ all the Software to download is the 3.00.2 version and not the 3.23. Does anybody know where to download the 3.23 and what the difference is? Is the newfirmware automatically installed although offline? I have 2.20 and is it worth upgrading? Do I have to programm new?
Yes the new firmware will upload if you are working offline.
There is no real difference between 3.0.0.2 and 3.23. As far as I can see is the most updates of products that are in version 3.23
My Bang & Olufsen....
THX
I have version 2.20 and is it worth upgrading to 3.00?
Do I have to programm everything new if I upgrade?
No, you should not.And you should not be nephew to your setup will be erased.
When you install the new CT3.0.0.2 becomes the old version uninstalled, but your settings will be saved.
And when you've installed CT3.0.0.2 and open the program you'll find out that your setup is still there.
