Latest post 12-13-2009 10:18 AM by Tillquist. 11 replies.
Page 1 of 1 (12 items)
  • 12-08-2009 11:56 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Config Software
    Could someone who has the config tool software please PM me. . .
    THanks
    MJM
    I'm ready for something new that I actually want to buy!
  • 12-09-2009 1:11 AM In reply to
    Re: Config Software
    google is your friend "peter pan B&O beo5 config HIFI4ALL.DK Forum"
    Cheers
    JK
  • 12-09-2009 2:10 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Re: Config Software
    That shows some "problems" when completed. . .
    any ideas?
    thanks
    also. . does it require a password?
  • 12-10-2009 2:31 AM In reply to
    Re: Config Software
    mjmedlo:
    any ideas?
    thanks
    No
  • 12-11-2009 11:39 AM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Re: Config Software
    I'm assuming "Work Offline" is the right way to tinker around with the
    BEO5 software?
  • 12-11-2009 12:30 PM In reply to
    Re: Config Software
    Yes - otherwise you need a B&O log in, which is not readily available.
  • 12-11-2009 12:55 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Re: Config Software
    Thank you.. .
    I'm assuming that nothing is really available until you connect a beo5 to the software correct?
    I don't have any kind of options whatsoever . . (haven't connected the beo5 yet)
    Is there any type of manual for the software?
  • 12-11-2009 4:08 PM In reply to
    • OKF
    • Top 500 Contributor
    • Joined on 02-22-2008
    • Posts 204
    Re: Config Software
    Hi@ all
    the Software to download is the 3.00.2 version and not the 3.23. Does anybody know where to download the 3.23 and what the difference is?
    Is the newfirmware automatically installed although offline?
    I have 2.20 and is it worth upgrading? Do I have to programm new?
    Best regards Oliver
  • 12-11-2009 5:08 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Re: Config Software
    How and where do you "upload" the xml files?
  • 12-12-2009 3:07 AM In reply to
    Re: Config Software
    OKF:
    Hi@ all
    Yes the new firmware will upload if you are working offline.
    There is no real difference between 3.0.0.2 and 3.23. As far as I can see is the most updates of products that are in version 3.23
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 12-12-2009 3:20 PM In reply to
    • OKF
    • Posts 204
    Re: Config Software
    THX
    I have version 2.20 and is it worth upgrading to 3.00?
    Do I have to programm everything new if I upgrade?
    Best regards Oliver
  • 12-13-2009 10:18 AM In reply to
    Re: Config Software
    No, you should not.
    And you should not be nephew to your setup will be erased.
    When you install the new CT3.0.0.2 becomes the old version uninstalled, but your settings will be saved.
    And when you've installed CT3.0.0.2 and open the program you'll find out that your setup is still there.
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
