henrik: Ah ok. My intention was to daisychain two MCL2AVs, and I assumed that they contain RF amps which would be of great help.
In a daisychain arrangement, then yes, you are right! They do have amping in the RF.
COAX in / COAX out ---> COAX in. Feed the COAX from the front of each MCL2AV out to its respective TV.
If you pull the 2AV grey plastic panel off, then pull the metal shield over the COAX area off... (which you have to do anyway...) you will see two threaded bosses to terminate and secure the COAX. There are even instructions printed on the board for the lengths of COAX cropping!
As a gold member... I would highly recommend dloading the System Manual 89 90 for MCL2... it should have everything you need w/ regards to installing these.
EDIT... Here is a pic!
