Latest post 12-05-2009 11:26 AM by DrDimitris. 4 replies.
Page 1 of 1 (5 items)
  • 12-05-2009 10:06 AM
    Speaker option 4 vs. 5
    Hi all,
    I have a BL7-1 as center speaker on my BV7-32. 2 BL 8000's as fronts and 2 BL4000's as rears. I have noticed that speaker option 4 on my BEO4 gives a more ''complete sound'' where the speaker option 5 gives my BL7-1 a big boost that dominates over the other speakers. Is there a trick to reduce the volume on my center speaker? I have set the correct distances of the speakers on settings menu. There is no sub on the system….yet.
    Any clues ??
    -Dimitris
  • 12-05-2009 10:33 AM In reply to
    Re: Speaker option 4 vs. 5
    In our 7-40's menu there is a setting that allows the relative volume levels of the speakers to be set.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 12-05-2009 11:11 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    You can`t reduce volume for the center. Just increase volume of front- and rear speakers, this will change balance of the speakers and will give you the same result.
    SPEAKER 5 is meant for surround sound, DD or DTS 5 (.1) channel decoded. SPEAKER 4 is 2x stereo (front stereo, rear stereo).
    So listen to a 5.1 DD or DTS DVD before changing the sound settings.
    Stefan
  • 12-05-2009 11:20 AM In reply to
    • MikaelB
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Herning, Denmark
    • Posts 191
    stefan:
    I agree with Stefan here. The reason for a dominating center speaker in Speaker 5 mode, could be that you were listening to a mono signal, then almost all the sound will come form the center speaker.
    /MikaelB
  • 12-05-2009 11:26 AM In reply to
    Thank you for the prompt answers. Indeed increasing the levels of the other speakers and playing a little with the balance front/rear things got better. Thank you
    -Dimitris
